I want to know where the coolant system air bleed is at so I can bleed the air out of the system to try and fix my heater issues? Both my heater hoses are hot, and all my fluids are full. So I believe my thermostat is stuck open causing my heater to blow cold. I am also checking the fuses just in case. If I could find the bleed for the coolant system I would like to do this before the thermostat so I do not do more work than I have to. I do not have any of the tools required to check the thermostat, so I want to make sure it is not something simple before I go replacing it. Also, if it does need replaced I want to bleed the air to make sure I have done the job properly. Any other ideas on what it could be? Please let me know! Thanks for your help!
SPONSORED LINKS
Friday, November 25th, 2016 AT 11:46 PM
