Heater not working?
It is okay, if you want to wait until the weather gets cooler. It will not damage anything. The only thing it will effect is the defroster operation.
Monday, December 28th, 2020 AT 12:43 PM (Merged)
BENFSHOOK
  • 2002 FORD RANGER
  • 6 CYL
  • 167,000 MILES
2002 3.0 V6 Auto. Tran. When I start my truck to warm up, no warm air is blowing until I am on the road. It doesn't matter if it idles for 5 minutes or 30 minutes. Yesterday while driving, I lost heat, cold air started to blow, and my engine temp went up as if it was starting to overheat. What could the problem be?
  • 110,176 POSTS
First, make sure the coolant level is full. If it is, then one of three things would be my guess-- First could be a simple air lock in the system. THe other is a bad head gasket. Also, if you haven't replaced the thermostat, now would be a good time to do it to see if it helps.
Let me know what you find.
CSOSA123456
  • 31 POSTS
It turned out to be the heater return line going from the water pump to the expansion tank and the heater core. The outlet for the heater core line was completely plugged solid.
Had to take off the A/C compressor, the alternator, the bracket that holds the tensioner. The exhaust manifold, the air intake. Basically the entire engine.
The hose was pretty much a nightmare to repair but it solved the problem.
Good job.
Glad to hear it is fixed.
PAUL GHIDONI
  • 2002 FORD RANGER
  • 6 CYL
  • 4WD
  • 70,000 MILES
Up until a couple of weeks ago I had heat, no longer. I thought it maybe the thermostat but its not. My top radiator hose gets hot, lower hose warm, my inlet hose to heater core hot, but the outlet hose doesn't even get luke warm. Could my heater core be clogged?
BLUELIGHTNIN6
  • 16,542 POSTS
Both inlet and outlet hoses from heater core should be hot to touch if engine is at operating temp. If not then heater core is most likely clogged.
MVF6
  • 2002 FORD RANGER
  • 4 CYL
  • MANUAL
  • 102,000 MILES
Is there a way to tell if my water pump or termostat is not working? My temp gauge does not register any temp and I have no heat. From various sources on the web it seems like it may be either the thermostat or the water pump. Before I replace one or the other I would like to narrow down the problem. Also if it is the thermostat I have conflicting repair solutions. Some say I can just replace the thermostat other say Ford made a change and now it is not possible to change the termostat beacuse it is part of a larger more expensive component. I didn't have a repair manual but have bought one and it is in the mail.
Thanks for any help.
BLACKOP555
  • 10,386 POSTS
Temp guage stays on cold? Belive me if the thermostat or water pump was bad it would overheat, and it would overheat fast.
I think you should make sure you have enough coolant in the vehicle first.
DIESEL2017
  • 5 POSTS
  • 2001 FORD RANGER
  • 6 CYL
  • 4WD
  • 90,000 MILES
I just recently noticed the heater isnt working like it should. The blower is working fine and its pumping the air out fast but its not really hot air. More like luke warm. Before I could start the truck up in the middle of winter, let it run for 5 min and when you got inside it was really warm. Now it takes about 15-20 mins just to get it a little warm. Even when driving it after letting it warm up, it never really gets warm to the point that you have to turn the heater down. Its slowly gettin worse and worse. At 90,000 miles and never having a problem, im not surprised something is starting to go bad so I cant complain about the truck. So is there something I should look at first to solve the problem? My guess would be the thermostat?
  • 110,176 POSTS
A few things can cause this type of problem. If the thermostat is the problem, you will know by paying attention to the temperature gauge. If the engine never warms up properly, then chances are it is the t-stat. If the truck engine warms up normally and in a reasonable amount of time, chances are the t-stat is fine. Also, make sure the coolant level is full.
Check those two things and let me know what you find. If they are okay, we will move on to a couple simple tests.
DIESEL2017
  • 5 POSTS
Well, the temperature gauge doesnt work, hasnt since last winter. I had called a local auto repair shop in town to ask them if it would hurt anything leaving it the way it was, and they said no as long as I am checking the coolant routinely. I only drive the truck in the winter time, and its stored in the garage pretty much all summer. When I told him that he said dont even worry about the gauge seeing is how I barely drive it. But I do know that last winter the heater worked really well when the temperature gauge wasnt working. Now this winter something obviously went bad because its not putting out that much heat.
STEVE COTTLE2
  • 2000 FORD RANGER
  • 4.0L
  • V6
  • 4WD
  • 116,000 MILES
My truck starts out cold even though it is garaged over night. The gauge is at the very bottom of the dial and sits there for at least ten miles of driving. The gauge finally starts to climb and then pegs out and the "check engine" light comes on for a second and then the gauge drops back down to normal. The heater blows cold air out even though the gauge says the truck is warm. The heat starts to blow out of the vents after about three or four miles of driving. When stopped the overflow reservoir is topped out and the cap is usually popped off. The radiator is about one to two quarts low then. I have had the system flushed and a new thermostat installed. The hoses are warm to hot when the engine is running. Could it be the heater core not operating correctly?
Monday, December 28th, 2020 AT 12:44 PM (Merged)
AL514
  • 5,513 POSTS
There could be a couple things going on here. Have the ECM scanned and get the diagnostic code from the computer, It sounds like you may have a bad head gasket if the radiator is doing weird things like that. Compression gasses may be getting into the coolant system causing too much pressure and it is just acting strange at different engine temperatures. Scan for engine codes and let us know what you find.
STEVE COTTLE2
I took it back into the shop where I had the system flushed and thermostat replaced. They said it could possibly be the head gasket. I will let you know their findings.
AL514
  • 5,513 POSTS
Good call, it is kind of their issue if it wasn't doing this before the coolant system was serviced.
