Heads
240,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
BOWSER520
Ok my head gasket blew I put another one on and put everything back together just like I took it off and when I went to start it it turned over a few times and the acted like it locked up but was not I took the number one plug out and manually rotated the motor then I noticed a lot of fuel flowing out of that cylinder and was told it was fuel regulator so I replaced it and tried starting again but it turned over sluggish and then it started for a couple of sec and then I heard alot of fuel flowing from somewhere the whole driverside of motor was wet from it but not sure where it came from so I took the numb one plug out again and same thing fuel was flowing out like crazy and before I took plug out then I tried starting it one more time and my starter burned up and I have no clue as what to do
Mar 28, 2017 at 11:17 AM
HMAC300
  • 48,601 POSTS
check fuel pressure first with a gauge should be 41-47 psi auto parts rent it. then check for a bad injector/s may be the problem dumping fuel
Mar 29, 2017 at 12:19 AM
