HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
S-10
Engine
Cylinder Head
Gasket
1997 Chevy S-10 head gasket
ABIGTONY38
MEMBER
1997 CHEVROLET S-10
Engine Mechanical problem
1997 Chevy S-10 4 cyl Two Wheel Drive Automatic 107.00 miles
how do I adjust the rocker arms, and what is the tourqe ft lbs I should use and the correct pattern. And help would be great
Wednesday, June 30th, 2010 AT 5:25 PM
BLUELIGHTNIN6
MECHANIC
Rocker arms with press in studs, stud tighten to 35 ft. Lbs. And nut to 18 ft. Lbs.
Rocker arms with screw in studs, stud tighten to 35 ft. Lbs. And nut to 19 ft. Lbs.
Hydraulic lifters are used, an adjustment is not needed
Wednesday, June 30th, 2010 AT 5:47 PM
Please
login
or
register
to post a reply.
Related Cylinder Head Gasket Content
1991 Chevy S-10 Head Gasket
Engine Mechanical Problem 1991 Chevy S-10 4 Cyl Two Wheel Drive Automatic How Much Do I Expect To Pay To Have My Head Gaskets Repaired...
Asked by
coltsvb_8
1 ANSWER
1991
CHEVROLET S-10
VIDEO
Can You Fix a Head Gasket with a Sealer?
Instructional repair video
GUIDE
Cylinder Head Gasket Blown Symptoms
A head gasket failure must be caught early to help protect the engine from additional damage. Understanding and recognizing these symptoms will be beneficial to your ...
1999 Chevy S-10 Possible Head Gasket??
I Have A 4 Cyl. Manual Trans. 99 Chevy S10. When I Start It Up There's A Terrible Rattle Coming From The Catalytic Converter, Which I Will...
Asked by
jtvanmeter
1 ANSWER
1999
CHEVROLET S-10
1994 Chevy S-10 Cylinder Heads
We Had To Rebuild A Blown Head Gasket On My Dads Truck. We Got A New Head From Salvage. Told Us That The Cylinder Heads Were Interchangeble...
Asked by
bunyanbaby
1 ANSWER
1994
CHEVROLET S-10
Heads
Ok My Head Gasket Blew I Put Another One On And Put Everything Back Together Just Like I Took It Off And When I Went To Start It It Turned...
Asked by
Bowser520
1 ANSWER
1996
CHEVROLET S-10
1999 Chevrolet S-10 Cylinder Head Help
Hello All, I Have A 1999 S10 Pickup 2.2l Rwd. I Have To Replace The Cylinder Head And Gasket But When I'm Online At Orileys Its Listing...
Asked by
redsnapper88
1999
CHEVROLET S-10
VIEW MORE
Coolant Mixing With Engine Oil
Oil Change and Filter Replacement Dodge Ram
