Hard to start when engine is hot
98,000 MILES
LITTA1973
My 1995 Dodge Spirit, 3.0 6 cyl is having a hard time starting when the engine is hot. Starts fine in the morning after sitting all night. I did a voltage test on the battery and its fine so i cleaned up all the contacts and the ground but still having the same problem. Do I need a new starter?
Jul 4, 2013 at 10:39 AM
  • 110,248 POSTS
Check for vacuum leaks and check the idle air control valve. Make sure the fuel pressure isn't dropping off. If you need direct
Jul 4, 2013 at 10:57 AM
  • 110,248 POSTS
Sorry about that... If you need directions, they are on the homepage under the DIY.
Jul 4, 2013 at 10:58 AM
