2004 GMC Yukon Pulsing Lights
MOMOF2RS
Headlights, interior and dash lights (not radio and climate control lights) pulse. Alternator test shows OK, so does battery test.
2004 GMC Yukon 77,000miles
Sep 25, 2007 at 1:43 PM
BMRFIXIT
  • 19,053 POSTS
[quote:c3008702e1="momof2rs"]Headlights, interior and dash lights (not radio and climate control lights) pulse. Alternator test shows OK, so does battery test.
2004 GMC Yukon 77,000miles[/quote:c3008702e1]
check ground and check headlights switch+
scan your BCM or try to moniter data in and out the BCM
Sep 25, 2007 at 2:30 PM
Suggested Repair
Check grounds and the headlight switch, and scan or monitor BCM input and output data.
Conversation Summary
The owner of a 2004 GMC Yukon reported pulsing headlights, interior lights, and dash lights, while radio and climate-control lights stayed steady. Battery and alternator tests passed. The expert advised checking grounds and the headlight switch and scanning or monitoring BCM data in and out.
