1997 yukon stuck in park
1997 GMC YUKON
GARJESS
1997 4wd two door yukon. Auto trans shift on the column. The shift lever is stuck in park. If I try long enough and push the brake several times I can get it to work and sometimes it just works normally. When I can get it out of park everything else is fine. It shifts through the gears fine and drives fine. Any suggestions. Thanks Gary
Aug 8, 2007 at 9:39 AM
CLY
  • 308 POSTS
You are probably have one of two things giving you the problem. It is either the brake switch or the Brake/Transmission Shift Interlock Solenoid(BTSI) it is loated in the steering column. If you look on the bottom of the column You should see a hole in the plastic cover. You can us a small screw driver and insert it into the hole to push the plunger up for the BTSI solenoid....
Cly
Aug 8, 2007 at 11:26 AM
