1999 GMC Yukon No reverse, no 2nd gear
1999 GMC YUKON
140,000 MILES • V8 • 4WD • AUTOMATIC
DAN051967
Hi - I'm hoping to find some help here... I have a 99 GMC Yukon that has a transmission problem. While getting onto the highway this morning, I was getting up to highway speed (65-70) when I heard a "pop" from under the truck. From then on, the ride seemed odd but I kept going (I was late for work!)
Once I got off the highway I noticed something else. When starting from a stop, the transmission seems to "miss" second gear - the engine revs to about 4000 RPM then I let off the accelerator, it will shift. Now I also noticed that it was also not going into overdrive.
When I got to work I was about to back into a parking spot when I put the transmission into reverse, it was acting like it was in neutral.
What is it and how expensive??
Apr 14, 2008 at 9:51 AM
BLACKOP555
  • 10,386 POSTS
i have a feeling your transmission is not having a rough 1-2 shift but a 1-3 shift completely jumping second gear, probably the sun shell gear is no good, take it to a trans shop for a rebuild.
that is the #1 cause for no 2nd gear, reverse or OD.
Apr 14, 2008 at 12:28 PM
DAN051967
Hi Blackop555, I just wanted to let you know you got it 100% right - the sun shell gear was broken completely in half. Luckily the torque converter was OK, no problems there. But, the rest of the transmission will have to be re-built. I live in Massachusetts and of course everything is expensive here; this is going to be a $3,000.00 repair. OUCH!
Thanks again for the info, Blackop555... I appreciate your help with this!
Apr 16, 2008 at 9:11 AM
BLACKOP555
  • 10,386 POSTS
no problem, gald to hear i was able to help you with your problem.
Apr 16, 2008 at 9:16 AM
