Hello balla4life2369
The ignition switch is most likely the problem but before assuming that it is good idea to check everything. Check for loose or corroded battery cables (Inspect, clean and tighten BOTH ends of BOTH battery cables).
Bad starter relay wiring connections or ground connection (Inspect, clean, tighten wiring connections).
Bad starter relay/solenoid (Check for voltage at relay, if relay has voltage but there is no "click" when key is turned to start, replace relay).
Bad starter (Jump battery voltage direct to starter to see if it spins, or remove starter and have it bench tested at auto parts
store).
Bad ignition switch (Check to see if voltage reaches starter relay/solenoid when turn to start. If not, check for open P/N switch. Replace ignition switch if defective).
Use test light or voltmeter to check for voltage passing through switch when ignition is turned to start.
SPONSORED LINKS
Wednesday, February 24th, 2010 AT 7:32 AM
