1. CPS problem the vehicle w/n start at all-it started when you prime it-right
2. Clogged C/Converter will choke its breathing and engine will not start or lost of power
3. The O2 sensors will not prevent the engine from starting.
Check the fuel pressure to rule out the fuel pump and also the oil pressure sending unit this is where you should start.
SPONSORED LINKS
Sunday, December 7th, 2008 AT 9:25 AM
