1993 GMC Suburban Fuel Compression Leak
1993 GMC SUBURBAN
142,000 MILES • V8 • 4WD • AUTOMATIC
ADAMANTADAM
When I took it to get it smogged, they told me I have a fuel compression leak and could not pass smog. I checked from the inlet up to the engine compartment and eveything looked good. I know it can be anywhere along the system, but is the a "common problem" area that I might check first, or is there a "handy-dandy" way of finding the leak? Thanks for you help.
Jan 11, 2010 at 4:41 AM
BLACKOP555
  • 10,386 POSTS
check the fuel pressure yourself and a fuel pressure leakdown and see if its leaking down.
if it was external youd smell gas.
Jan 11, 2010 at 10:37 AM
ADAMANTADAM
Thank you very much for the insite. I will research the fuel pressure leakdown, I don't smell gas, so maybe that's a good thing, :-) . I'll let you know how it goes, thanks again.
Jan 12, 2010 at 10:59 AM
