Air conditioner not blowing hard
250,000 MILES • 7.4L • V8 • 2WD • AUTOMATIC
KELLYMSMITH2002
I replaced the dryer and had the system put under vacuumed and filled, so it is blowing cold. But, it does not seem to be blowing very hard. It just cannot keep up with the Texas heat.
I thought it was maybe the interior air filter, but apparently the 1997 does not have one. So, what else do you think could be the problem? Should I just replace the whole blower?
Thanks in advance.
Jul 4, 2016 at 4:17 AM
CJ MEDEVAC
  • 11,000 POSTS
Maybe there is a blend door stuck or an actuator not in full motion. If fan speeds are the same when on different speed settings, it may be a fried blower motor resistor.
You can also look in here at "Climate Control".
https://www.2carpros.com/articles
Return with a grin!
The Medic
Jul 4, 2016 at 6:13 AM
KELLYMSMITH2002
Thanks!
Jul 4, 2016 at 6:17 AM
