2001 GMC Sonoma Hard Start Fuel Smell
good luck
jim
Extended crank is needed to restore pressure.
A pressure regulator won't cause a gas smell or reduce your mileage but a leaking injector will.
If capable... pull each spark plug to look for signs of fouling.
...if you find one that looks very sooty then pull the injector rail and take that one to a shop to have it cleaned/tested.
..running cleaners thru the system usually doesn't work
Suggested Repair
Inspect the fuel pressure regulator under the upper intake at the rear of the SFI poppet connector. It is round, has a relief tube, and is held by one clip. A leaking regulator can cause hard starts after sitting, fuel odor, and reduced mileage and should be replaced if leaking.
Conversation Summary
The owner of a 2001 GMC Sonoma 4.3 reports long cranking after the truck sits, worse fuel economy, and an occasional fuel smell with no visible leaks, and asks where the fuel pressure regulator is. An expert says it is under the upper intake at the rear of the poppet/SFI connector, held by one clip, and that a leaking regulator can cause cabin fuel odor and poor mileage. Another participant suggested a leaking injector and spark-plug inspection, but the expert said this engine uses under-intake poppet valves rather than removable individual injectors.
