1999 GMC Sonoma Fuel Filter Change
and if you don't like to be spit back find the relay or the pump fuse- start the engine then remove it and let it die on its own-now go attack that filter and what's out it might require a special tool to remove it-eye ball it first assess the situation than take action.
Remember No smoking and Childrens allowed while you doing this. Safety comes first before the filter.
Suggested Repair
Relieve fuel pressure before replacing the filter: locate the fuel pump fuse or relay, start the engine, remove the fuse or relay, and let the engine stall. Then replace the filter, using a special disconnect tool if the fittings require it. Avoid smoking and keep children away while working.
Conversation Summary
The owner of a 1999 GMC Sonoma with a 6-cylinder Vortec engine asked whether the fuel filter can simply be swapped, noting the box warns the system may be pressurized. One reply said the old filter can be pulled off but fuel will spray. Another advised depressurizing the system by removing the pump fuse or relay and letting the engine die, then replacing the filter, checking first whether a special tool is needed, and following basic safety precautions.
