1994 GMC Sonoma Starting
LOUMSC
  • 1994 GMC SONOMA
  • 6 CYL
  • 190,000 MILES
Will start cold but will not start after warmed up
Have replaced coil wire, plug wires, distrib cap, rotor and plugs
Saturday, June 19th, 2010 AT 7:39 PM
INTERNETMECHANIC
  • 700 POSTS
Are there any applicable trouble codes? When the problem occurs, have a helper crank it, while you visually check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage if you don't have one.
To test for spark, pull a spark plug wire loose, use a known good plug or spark tester in the boot. Ground metal part of plug/tester to metal part of engine, watch for spark, engine cranking. With temp related issues, sometimes the cts can cause problems? I don't replace anything without trying to be sure.
Sunday, June 20th, 2010 AT 12:02 PM
LOUMSC
  • 5 POSTS
No there are no fault codes, Just sends back code 12 and no other codes. By cts did you mean coolant temperature sensor?
Thanx,
Lou
Sunday, June 20th, 2010 AT 12:32 PM
INTERNETMECHANIC
  • 700 POSTS
I can not tell you the coolant temp sensor is faulty, just one possibility? I'd still want to check for spark and fuel pressure.
Sunday, June 20th, 2010 AT 2:00 PM
