Will start when cold but after running for a while it will not start again
Saturday, June 19th, 2010 AT 7:35 PM
HMAC300
MECHANIC
Run a scan on it to see if anything shows up. It could be a crank sensor that has gone bad but won't show up on a scan also. Check fuel pressure and change the fuel filter.
SPONSORED LINKS
Sunday, June 20th, 2010 AT 6:50 PM
LOUMSC
MEMBER
Ran a scan using the diagnostic connector and the check engine light, no codes are reported, Just shows code 12
