1993 GMC Sonoma Wont' start occasionally
DJK4013
  • 1993 GMC SONOMA
Engine Performance problem
1993 GMC Sonoma 6 cyl Manual 131000 miles
My GMC will not start - it will turn over and fire but wont start. AFter about an hour or so, it will start. I hear the fuel pump kick on. What could be the problem, I don't know where to start?
Friday, October 9th, 2009 AT 5:09 PM
Check the fuel pressure to rule out the fuel filter, fuel pressure regulator and fuel pump. If okay test the IACV, TPS and MAP sensor
Friday, October 9th, 2009 AT 6:09 PM
DJK4013
  • 5 POSTS
How do you check the fuel pressure?
Also, I just went to try to start it to get it home, now, it will not start. It is turning over and sparking and I hear the fuel pump kick on too.
Friday, October 9th, 2009 AT 7:25 PM
Is it a TBI or CFI fuel system?
Friday, October 9th, 2009 AT 8:14 PM
DJK4013
  • 5 POSTS
TBI.
I'm starting to think it's the timing. When it did run (this morning) it seemed to be idiling a little fast. Could this be it? Not outraegous, just little faster than normal.
How do I check this and/or replace?
My spark plugs and plug wires are only about 2 years old. The fuel pump is two years old too. I know it's not the fuel pump, I can hear it kick on.
Friday, October 9th, 2009 AT 8:22 PM
