HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
GMC
Sonoma
Engine
Symptoms
Not Running
1993 GMC Sonoma
WYNKOOP
MEMBER
1993 GMC SONOMA
6 CYL
2WD
MANUAL
10,000 MILES
Truck will not start it has new battry just will not trune
Wednesday, December 30th, 2009 AT 5:17 PM
MECHANIC
No crank at all/nothing/nada:
Could be the starter, starter relay, park and neutral switch, clutch switch and ignition switch assuming the battery and connections are good.
SPONSORED LINKS
Wednesday, December 30th, 2009 AT 6:17 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1993 Gmc Sonoma Wont' Start Occasionally
Engine Performance Problem 1993 Gmc Sonoma 6 Cyl Manual 131000 Miles My Gmc Will Not Start - It Will Turn Over And Fire But Wont Start...
Asked by
djk4013
1993
GMC SONOMA
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
Won't Start
93 Sonoma 2wd, 4.3 Vortex, Has Spark And 61 Psi Fuel Pressure At The Fuel Rail, Fuses All Good, No Codes On The Obd-1, Suspect Injectors...
Asked by
daveainoa
1993
GMC SONOMA
1993 Gmc Sonoma Want Start
It Was Runing Ok Then It Would Not Start Put New Battery In And It Was Ok Untill The Next Day Would Not Start.I Take Starter Off Put New One...
Asked by
wynkoop
1 ANSWER
1993
GMC SONOMA
Engine Turns Over But Won't Fire
2.2 Liter 1998 Sonoma Died On The Road. It Turns Over But Won't Start It Was Running Fine, But Now It Won't Start. With Nearly 300,000...
Asked by
jstu60
9 IMAGES
1998
GMC SONOMA
Turn Key Lights And Guages Work But Wont Start Or Turn...
I Turn On Key And Every Thing Came On But It Would Not Turn Over. Turned Key About 5 Or 10 Times And It Starts Up. It Keeps Starting But...
Asked by
JoeVal
1 ANSWER
2001
GMC SONOMA
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
