When it refuses to crank, did you try cranking in neutral? If that doesn't work, I'd have to check the circuits at the starter relay, underhood fuse box. The load side of relay is hot all the time. The coil side of relay goes hot with the key in the crank position.
SPONSORED LINKS
Sunday, August 23rd, 2009 AT 10:10 AM
