Truck ran great, overnight will not start
247,000 MILES • V6 • 2WD • AUTOMATIC
KYBORHAL
Okay, this truck has been well maintained and has always been a trooper. Drove from Indiana to Delaware no problems, after two weeks in Delaware it stopped working. She cranks over but will not start. Battery is good, fuel pump whines when you turn the ignition on, tried starting it in neutral, no difference. I connected it to a reader and it says no codes (despite the check engine light being on). I retry and it says no connection. The reader is good i tested it on my own truck. Any suggestions on what to try next would be greatly appreciated, at over 250,000 miles i really do not want to have it towed to a shop.
Dec 14, 2016 at 5:38 AM
KYBORHAL
Additional info: Do not think it is the MAF sensor, had a similar problem with a 1997 F150 and it would start after I disconnected the sensor, tried it, no effect. Also, with the key turned to start, while the engine is cranking, it will go on and on and on. As soon as I let the key fall back to the normal position the engine sputters, but does not catch.
Dec 14, 2016 at 6:00 AM
HMAC300
  • 48,601 POSTS
scan for codes with a different reader and check fuel pressure with a gauge auto parts rent it. See link.
Dec 14, 2016 at 7:35 AM
