2002 GMC Sierra Truck will crank but wont start.
ERNIE RAMIREZ
  • 2002 GMC SIERRA
  • V8
  • 125,000 MILES
I believe it has a fuel pump reset button but I cant locate it. If this is not the case what else could it be?
Wednesday, January 9th, 2008 AT 4:05 PM
MASTERTECHTIM
  • 4,749 POSTS
It does not have a reset button. Will it run on starting fluid?
Wednesday, January 9th, 2008 AT 4:25 PM
ERNIE RAMIREZ
Truck will not start with starting fluid. Is it possible my alarm has disabled the fuel pump? I have not used the keyless entry remote because ive misplaced it. If this is the case can I disable the alarm?
Wednesday, January 9th, 2008 AT 5:30 PM
MASTERTECHTIM
  • 4,749 POSTS
If it was an alrm problem your truck would start and then stall 2 seconds later and run on starting fluid, so a security problem is not the issue. Have you checked the basics like spark. Check spark at the spark plug, if no spark at the plug, remove coil wire from coil tower and see if you have spark there, if you do than your problem is the coil wire and or the distributor cap and rotor.
Wednesday, January 9th, 2008 AT 5:40 PM
ERNIE RAMIREZ
Thank you for your help. Will check asap. Will make a donation as soon as possible.
Wednesday, January 9th, 2008 AT 6:07 PM
