2002 GMC Sierra Oil Leak
2002 GMC SIERRA
144,000 MILES • V8 • 4WD • AUTOMATIC
CMIYC32
I have been noticing a oil leak in the drive, I just had an oil change and that very same day I had about palm size oil leak on the drive. What should I have checked FIRST thing? It is running great, but concerns me badly...
Feb 20, 2008 at 1:15 AM
FAST92LT1RS
  • 13 POSTS
I have an '03 and change my own oil. When the oil is draining some drips into the crossmember directly under the drain plug. If it is not wiped out it will slowly leak onto the ground. I would roll under the truck and see if there is any oil in that area.
-Pete
Feb 20, 2008 at 11:08 AM
