2001 GMC Sierra Window Won't Roll Up
Hey bigK
That style truck has a whole "window regulator/motor assembly" and its cable operated, its quite a "contraption". And a pretty lengthy task if your up to it, rivets need to be drilled out etc.....but I would recommend taking it to a trusted shop for repairs.
Regards,
Chris
Thanks for the update GMX!
Chris
Suggested Repair
Replace the cable-operated power window regulator and motor assembly. On a 2001 Sierra it is typically secured with 10mm bolts, with two 7mm screws for the door panel; a shop repair is reasonable, and dealer cost was reported at a little over $400 per window.
Conversation Summary
The owner of a 2001 GMC Sierra heard a crackling sound while lowering the driver window. It would then rise only about one-quarter of the way, although it still lowered normally, and the owner had to force it closed. An expert said these trucks use a cable-operated regulator and motor assembly and recommended a trusted shop. Another commenter said a 2001 uses 10mm regulator bolts rather than rivets and two 7mm door-panel screws. A third owner reported the same problem on both front windows and paid a little over $400 per window at the dealer after abandoning a DIY repair.
