I NEED TO REPLACE THE WINDOW LIFT MOTOR. HOW DO I REMOVE THE WINDOW
Sunday, May 17th, 2009 AT 9:44 AM
DR LOOT
MECHANIC
Replacing window regulators can be very tough especially on the truck you're working on, you will need to unbolt the entire inside of the door support, or with a drill removed the rivits not hold the motor to the support, you better purchasing manual to help you.
