Passenger side Windows wont work
84,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
BILLKUBO
Neither of the passengers side windows will go up or down. Hear click when button is pressed but nothing. This is a four door pickup and both windows on this side are like this. Replaced master control switch on Driver side (no help) swaped passenger switches (no help)
Need help figuring this out. Its driving me crazy. Thanks in advance.
Jul 4, 2016 at 5:17 PM
HMAC300
  • 48,601 POSTS
if you are hearing a click check for a broken cable or piece broken in regulator on both windows. you will have to pull the door panel off to see this.
Jul 4, 2016 at 11:00 PM
BILLKUBO
Found a short in the junction box to the rear passenger window. Still no power to front passenger window though. Regulator and cables seem to be good.
Aug 1, 2016 at 7:19 PM
HMAC300
  • 48,601 POSTS
check for a broken wire at door jamb it may have power on the one side but not the other.
Aug 1, 2016 at 10:35 PM
