2000 GMC Sierra Starting problem
140,000 MILES • V8 • 4WD • AUTOMATIC
SFCJDHERRERA
  • 6 POSTS
The engine will start only on the second crank.
Someone told me that there is a fuel pressure check valve that may be faulty allowing fuel pressure to bleed back into the fuel pump. Is that true and is it part of the fuel pump?
Jul 24, 2009 at 8:39 AM
  • 110,251 POSTS
Actually, that is true. There is one in the fuel filter and the pump. An easy way to check if that is the problem is to do a fuel pump pressure test. Then when you shut the key, the system should hold pressure for at least 10 minutes and not completely bleed off. Here is the instructions for checking fuel pump pressure. Remember, you are more interested in fuel pressure bleed off. That is when the key is turned off and the pump stops working. You need to see if the system holds pressure.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know the results.
PS: If you don't have the gauge (most people don't) many nationally recognized parts stores will lend or rent it to you.
Jul 24, 2009 at 3:47 PM
