2000 GMC Sierra Engine will not start
2000 GMC SIERRA
LEEYOUNGKAN
  • 14 POSTS
Electrical problem
2000 GMC Sierra 6 cyl Two Wheel Drive Automatic
Performed major tune-up(cap, rotor, plugs, wires,air filter and fuel filter). Got a crank sensor intermittent code, which prompt me to check the integrity of CS, ignition module and the coil. All these components checked out OK, so I decided to replace the VCM. I purchased a reman VCM, did the relearn procedure, but truck still has the same problem. I suspect the reman might be defective. Note! I also checked voltages and ground to VCM and they are all good. I also tried a junk yard VCM, which starts the car, but dies instantly.
Nov 4, 2010 at 2:19 PM
What are you missing spark or fuel?
Nov 4, 2010 at 2:27 PM
LEEYOUNGKAN
  • 14 POSTS
Fuel press is OK, I have no spark
Nov 4, 2010 at 2:35 PM
Fuel pressure okay-but is it getting into the cylinders -check if the injectors are pulsing
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Nov 4, 2010 at 2:38 PM
LEEYOUNGKAN
  • 14 POSTS
I'm not concerned about the injectors, as I mentioned that the truck starts with the junk yard computer, but stalls instantly. I am just not getting any spark to the plugs, which I checked while cranking.
Nov 4, 2010 at 2:49 PM
