2000 GMC Sierra Stalls After Water
LILRAMBOIMPELL
i have a 2000 gmc sierra 1500 5.3L 323 i went offroading through a pond and ever since then its been stalling out on me. now i have replaced the spark plug wires and plugs gave it an oil change and put dry gas in the tank which didnt seem to help very much. what else is there that i could check for to get my truck running back to normal. thanks
Nov 16, 2007 at 2:27 AM
DENNYP
  • 1,824 POSTS
you need to visually inspect all electrical modules that were exposed to the water for any signs of water intrusion.If they have water in them or have corrosion,replace them.
Nov 16, 2007 at 11:39 AM
Suggested Repair
Visually inspect all electrical modules that were exposed to water. If any show water intrusion or corrosion, replace them.
Conversation Summary
A 2000 GMC Sierra 1500 5.3L began stalling after driving through a pond. Spark plugs and wires were replaced, the oil was changed, and dry gas was added without much improvement. The expert advised inspecting water-exposed electrical modules for intrusion or corrosion and replacing any affected modules.
