2001 GMC Sierra Hard Start Stall
TRUCK TALK
My GMC Sierra is a 2001. Engine is a V-8 Vortex 4.8 Liter. Odometer is approx.30,000 miles. Automatic trans. Truck starts quickly on cold starts, however truck will idle slightly rough when engine warms up. When truck sits for about 15 minutes to 2 hours or so, it takes about 5 to 10 seconds before it starts. If you don't give it gas right away then it may stall, and you can smell a fuel scent after starting. Also, coming off freeway to a stop, sometimes truck may stall but will restart easily. Fuel filter has been replaced and carburater cleaner has been used to correct the problem, with no improvement. Truck has full running power when accelerating. Thanks.......
Oct 1, 2007 at 3:31 PM
SERVICE WRITER
  • 9,123 POSTS
No codes?
Check the fuel pressure when the problem is happening. Check with the key on engine (koeo) on when the problem is present. Pressure HAS to be at least 61 psi, nothing less. IF it is, get a pump and and replace the elctrical connector to the pump.
Also, Check the vacuum line to the fuel pressure regulator, if there is fuel in it, replace it. This is probably the questionable part as your smelling raw fuel.
Oct 1, 2007 at 10:07 PM
Suggested Repair
With the key on and engine off while the hard-start condition is present, confirm fuel pressure is at least 61 psi. If pressure is low, replace the fuel pump and its electrical connector. Also inspect the vacuum line to the fuel pressure regulator; if fuel is present, replace the regulator, which is the likely cause of the raw fuel smell.
Conversation Summary
A 2001 GMC Sierra with a 4.8L V8 starts quickly when cold but idles slightly rough when warm. After sitting 15 minutes to about 2 hours it cranks 5–10 seconds, may stall unless given throttle, and smells of fuel. It can also stall when stopping after freeway driving but restarts easily, and it has full power under acceleration. The fuel filter and carburetor cleaner did not help. The expert advised checking for codes and measuring key-on fuel pressure during the problem (at least 61 psi), replacing the pump and connector if pressure is low, and replacing the fuel pressure regulator if fuel is found in its vacuum line.
