1999 GMC Sierra Won't Start
GRAVEDIGGER1
  • 1999 GMC SIERRA
  • V8
  • 4WD
  • 110,000 MILES
This morning I started my truck and it ran just fine for a few minutes and shut off. Then I tried to start it again and it would run a little bit and shut off. I was told to try the fuel filter so I changed that and still have the same problem. What should I check. The truck won't pull up any codes on my diagnostic scanner.
Thursday, January 21st, 2010 AT 12:27 PM
JDL
  • 16,098 POSTS
Welcome to the forum, do you think the security system might be causing an issue? Use a gage and check fuel pressure. Some of the national brand autostores used to loan a fuel pressure gage. You can call and ask. The fuel poppets are known to stick, if you have the spider fuel system. The cleaning procedure in the service bulletin, is a shop procedure. Right now, I'm not sure what is causing the problem?
Thursday, January 21st, 2010 AT 1:17 PM
