HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
GMC
Sierra
Engine
Symptoms
Not Running
1999 GMC Sierra Will not start
BOYDJ
MEMBER
1999 GMC SIERRA
V8
4WD
AUTOMATIC
136,000 MILES
The motor will turn over but, will not start. I hav e replaced the fuel pump. The engine has fire. What else can I check?
Wednesday, June 30th, 2010 AT 6:03 PM
MECHANIC
If you can hear the fuel pump come On for 2secs-do below
Verify the fuel pressure if its within specs if okay -check if the injectors are pulsing-let me know
Wednesday, June 30th, 2010 AT 7:13 PM
INTERNETMECHANIC
MECHANIC
I'd have to use a gage and check fuel pressure. What is litre size of engine?
Wednesday, June 30th, 2010 AT 7:19 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
99 Sierra Turns Over But Wont Start
5.4l V8 98k Mi. We Have Fuel Pressure, And Spark. But This Truck Has Always Intermittently Sported A 'security' Light On The Message...
Asked by
jmaschle
1999
GMC SIERRA
VIDEO
Car Cranking but Not Starting? Try This
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
Wont Start
1999 Gmc Sierra Classic Will Crank But Wont Start Until I Put Jumper Cables To It. Have Had Battery Tested Replaced Starter, And Checked Alt...
Asked by
bigcountryky
1 ANSWER
1999
GMC SIERRA
1999 Gmc Sierra Won't Start
This Morning I Started My Truck And It Ran Just Fine For A Few Minutes And Shut Off. Then I Tried To Start It Again And It Would Run A...
Asked by
gravedigger1
1 ANSWER
1999
GMC SIERRA
1999 Gmc Sierra Engine Won't Start When Turned Over.
Hello. Truck Was Running Fine. The When I Tried To Start The Engine It Didn't Start But Head Lights Worked Radio Worked. Got A Tow Home And...
Asked by
1999GMC
1 ANSWER
1999
GMC SIERRA
Engine Doesnt' Want To Re-start
Truck Starts Fine When Cold, Difficult Starting After It Is Turned Off After It Is Warmed Up. 1999 Gmc Sierra 4.8l Engine. Bought The Truck...
Asked by
gwaleyd
1 ANSWER
1999
GMC SIERRA
VIEW MORE
How to fix an engine that wont start
Crankshaft Sensor Replacement
