1997 GMC Sierra wont start
HUTCH75
  • 1997 GMC SIERRA
Engine Mechanical problem
1997 GMC Sierra V8 Four Wheel Drive Automatic 266k miles
changed intake gaskets got it all put back together and it wont start. Got fire air fuel pressure compression distributor is good and alined put in new plugs and fuel filter and it still wont start
Sunday, March 21st, 2010 AT 2:04 PM
Hi hutch75, Welcome to 2carpros and TY for the donation
You got snapping blue spark and correct fuel pressure-are the injectors pulsing providing fuel?
Did you put the engine no.1 piston on its compression stroke/TDC before you pull the distributor if not the valve timing is off/could be 180deg out and also this will throw off the ignition timing.
Sunday, March 21st, 2010 AT 6:30 PM
