1997 GMC Sierra vehicle wont start
BRANNON
  • 1997 GMC SIERRA
Engine Mechanical problem
1997 GMC Sierra V8 Four Wheel Drive Automatic
vehicle gets fuel and is firing I replaced ignition module, crank position sensor
Tuesday, December 15th, 2009 AT 2:21 PM
No start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
_________________
Tuesday, December 15th, 2009 AT 3:37 PM
