1989 GMC Sierra will not start when truck is warmed up
JACQUE GESKIE
  • 1989 GMC SIERRA
Engine Performance problem
1989 GMC Sierra V8 Two Wheel Drive Automatic
my truck will not start after running for a while and is warmed up. I dont know what to do because my husband cant work on it beacause he has brain injuries. Can you pleaase give me some kind of idea what it vould be. Thank you so much, Jacque Geskie
Friday, June 18th, 2010 AT 10:44 PM
Check the fuel pressure if its within specs if not could be leaking thru the injectors and fuel pressure regulator causing the hard starts bcuz it won't hold the residual fuel pressure
Friday, June 18th, 2010 AT 10:50 PM
