2002 GMC Savana
STEVE GASS
  • 2002 GMC SAVANA
  • 6 CYL
  • 150,000 MILES
Van will not start unless some gas is poured in air intake runs fine and will restart but only if restart is within 5 minutes after shut off a good mechanic has looked at it and has no clue
Sunday, April 18th, 2010 AT 1:05 PM
HMAC300
  • 48,601 POSTS
Check for fuel pressure then check the injector under the plastic manifold to see if they are getting power or working at all. The lines are plastic and will break or crack, although you say it runs fine, so i'd try a pro injector cleaner first. Change your fuel filter as well.
Monday, July 12th, 2010 AT 2:10 PM
