One day my van cut out on me on the highway then started itself right back up after I let off the gas now it won't start at all replced the fuel filter and fuel pump also put a new distributor cap and rotor in it and just did the fuel injector spyder still nothing turns over rotor spins and if you spray starting fluid in the intake it runs of that?
SPONSORED LINKS
Monday, September 27th, 2010 AT 1:28 PM
JDL
MECHANIC
Use a gage and check fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage, if you don't have one. Also, use a noid lite and check for injector pulse.
