1995 GMC Safari No Fuel Pump Power
WITZEND
I have a 1995 GMC Safari that is not getting power to the fuel pump. I replaced the pump, as it was under warrantee, and I also tried a new relay. Niether of these helped. I also checked for voltage at the plug where the pump connects but get no reading. Any further suggestions would be greatly appreciated.
Jan 26, 2007 at 10:09 AM
SERVICE WRITER
  • 9,123 POSTS
Do you have any anti-theft controls on it?
Jan 26, 2007 at 12:51 PM
WITZEND
It does not have any anti-theft controls.
I did some more checking and I am confident that I have a connection from the relay to the pump, but can't find any voltage reading at the relay.
Jan 27, 2007 at 1:37 AM
SERVICE WRITER
  • 9,123 POSTS
Check your email for a diagram that shows a fuse that may have blown.
Jan 27, 2007 at 3:45 AM
WITZEND
Thanks for the diagram. While tracing down the wires I found one that was broken. After splicing it back together the van started right up.
I really appreciate your help.
Thank you!
Jan 31, 2007 at 1:21 PM
SERVICE WRITER
  • 9,123 POSTS
We like Fairytale endings :D
Jan 31, 2007 at 9:40 PM
Suggested Repair
Trace the fuel pump circuit from the relay, including the related fuse and wiring. A broken wire was found and splicing it restored power so the van started.
Conversation Summary
A 1995 GMC Safari had no power at the fuel pump. Replacing the pump and relay did not help, and there was no voltage at the pump connector or relay. Anti-theft was ruled out. After a wiring diagram pointed toward a possible blown fuse, tracing the wires revealed a broken wire. Splicing it restored power and the van started.
