1999 GMC Safari Interior Light and Blinker
SAFARI
Alright guys, as of late when I step on my accelerator in my 99 GMC Safari, my interior light comes on until I depress the pedal, also when I turn, my blinker will cut out momentarily. I'm not quite sure what the problem is, maybe loose wires?
Mar 22, 2006 at 3:57 AM
  • 55,627 POSTS
Sounds like you have the wrong/shorted bulb in the rear light socket, or the ground for the rear sockets are bad. Check to reapir as needed.
Mar 22, 2006 at 8:06 AM
Suggested Repair
Inspect the rear light sockets for a wrong or shorted bulb and check the grounds for the rear sockets. Repair as needed.
Conversation Summary
The owner of a 1999 GMC Safari says the interior light comes on when pressing the accelerator until the pedal is depressed, and the blinker cuts out momentarily when turning. They suspect loose wires. The expert suggests a wrong or shorted bulb in a rear light socket or a bad ground for the rear sockets, and recommends checking and repairing as needed.
