1984 GMC S15 Won't Turn Over
ACE
I have a 1984 S15 with like 150k miles and yesterday i left my lights on and i had get a jump and accedent had cable crossed i notice fast and switched car started fine then this morning when i start my car i didnt let it run cuz its old cuz i was running late and it stalled and i try to start back up and would not turn over i replace the starter like 3 months ago so i think thats good and batter has juice cuz it sparks but car wont get any power what do u think it is?
Mar 8, 2006 at 5:40 AM
PEPPERMRJ
  • 1,158 POSTS
[quote:b3bebd4836="ace"]I have a 1984 S15 with like 150k miles and yesterday i left my lights on and i had get a jump and accedent had cable crossed i notice fast and switched car started fine then this morning when i start my car i didnt let it run cuz its old cuz i was running late and it stalled and i try to start back up and would not turn over i replace the starter like 3 months ago so i think thats good and batter has juice cuz it sparks but car wont get any power what do u think it is?[/quote:b3bebd4836]
This is directly out of the repair manual.
"Be certain to observe correct polarity connections. Failure to do so will result in almost immediate computer, alternator and regulator destruction. Never allow the jumper cable ends to touch each other."
It could also cook the starter. A lot to check. Start with the main ignition fuse. Then with the starter. If you do get it running take it to have the alternator tested.
Mar 10, 2006 at 11:29 AM
Suggested Repair
Check the main ignition fuse first, then the starter. Reversed jumper cables can destroy the computer, alternator, and regulator and may also damage the starter. If the engine runs, have the alternator tested.
Conversation Summary
The owner of a 1984 GMC S15 said the vehicle would not turn over after a jump with briefly reversed cables, a short start, and a stall. The battery still sparks, and the starter was replaced recently. The expert warned that reverse polarity can destroy the computer, alternator, and regulator and may damage the starter, and advised checking the main ignition fuse, then the starter, and testing the alternator if it runs.
