1987 GMC S15 Broken Flywheel
88 CHEVY CAMARO350
[img:b02a21b908]http://www.2carpros.com/forum/automotive_pictures/94379_flywheel_1.jpg[/img:b02a21b908]I have a 1987 S15 4x4 with 125,768 miles but i just bought it from someone who said the tranny was blown. After some investigation i found the flywheel to be broken in a wierd way. The lady said the truck ran untill she shut it off so i don't belive the crank is broken however the bolts holding the tranny in place were so loose it took maybe 4 turns of the finger to remove them, My question is could that have caused the flywheel to break at the attachment bolts or could it be because the tranny locked up. The tranny seems to turn fine although i haven't had it turning because i need to replace the flywheel i just don't want to replace it only to have it fly into the cab. Any help would be much appreciated as i have never experienced this problem.
Aug 21, 2007 at 4:16 AM
CLY
  • 308 POSTS
I have seen that problem before on trucks and on the older rear wheel drive cars. I would bet that that thing was making noise for sometime before it let go. If it was mine I would stick a new one in there and go....
Note: I would replace the flywheel and torque converter bolts and use locktight on them...
Cly
Aug 21, 2007 at 10:13 AM
88 CHEVY CAMARO350
if u have seen it before what was the cause ? the flywheel and torque converter bolts were pretty tight although the tranny bolts to the block were loose and it looks as though there was a little work done under there so maybe they didn't tighten them. But thanks for the reply and the help i guess i will sling a new one in her and see what we get.
Aug 21, 2007 at 2:18 PM
CLY
  • 308 POSTS
It is hard to say what causes this but it starts off as a small crack and if not addressed quickly then you get the result that you see. It could have been that the car back-fired while attempting to start it or maybe a casting flaw it is hard to tell. But I have done several of these without any additional problems....
Cly
Aug 21, 2007 at 9:32 PM
88 CHEVY CAMARO350
ok then thanks for the responses and your time you've been very helpful to me. I just wanted to make sure it wasn't something else before reinstalling the new flywheel.Thank you very much
Aug 22, 2007 at 1:51 AM
Suggested Repair
Replace the flywheel and the torque converter bolts, apply thread locker, and torque them properly. The expert has seen this failure begin as a small crack, possibly from a start-up backfire or a casting flaw, and similar replacements have not caused further problems.
Conversation Summary
The owner of a 1987 GMC S15 found the flywheel broken at its attachment bolts after buying the truck with a reportedly failed transmission. The transmission-to-block bolts were very loose, raising concern about the crankshaft or a locked transmission. The expert said the cause is hard to pinpoint but that the damage likely started as a small crack, and recommended installing a new flywheel and torque converter bolts with thread locker.
