1989 GMC S15 Cranks But Won't Start
CARPDADDY86
i have an 89 gmc s15 and it cranks over but will not start. if i spray some starting fluid into the throttle body it will start and i can keep it running by hitting the peddle, but it sputters and cuts out when driving.i replaced the fuel filter and spark plugs,i would like to know some info so i dont have to buy all kinds of parts to see if they will fix it. my guess is a fuel pump
May 28, 2007 at 9:40 AM
  • 75,988 POSTS
[quote:b7ca274873="carpdaddy86"]i have an 89 gmc s15 and it cranks over but will not start. if i spray some starting fluid into the throttle body it will start and i can keep it running by hitting the peddle, but it sputters and cuts out when driving.i replaced the fuel filter and spark plugs,i would like to know some info so i dont have to buy all kinds of parts to see if they will fix it. my guess is a fuel pump[/quote:b7ca274873]
Check the fuel pressure to nail the fuel pump. Pump don't come On for 2secs while key is in run position-look for power at pump connector while engine is being crank.No power there check the fuel pump relay.No power to relay check the PCM>
May 29, 2007 at 8:35 PM
Suggested Repair
Check fuel pressure to confirm the fuel pump. Verify the pump primes for about two seconds with the key in run, and check for power at the pump connector while cranking. If there is no power, check the fuel pump relay; if the relay has no power, check the PCM.
Conversation Summary
The owner of a 1989 GMC S15 says it cranks but will not start unless starting fluid is sprayed into the throttle body, then sputters and cuts out while driving. The fuel filter and spark plugs were already replaced. The expert advises checking fuel pressure and pump power, then the fuel pump relay and PCM if power is missing.
