1995 Buick Park Avenue Will Not Start
1995 BUICK PARK AVENUE
CREMALEY2
I have a 1995 Buick Park Avenue 6 cylinder with approx. 50m miles (I put in another motor that had 37,000 miles on it) and it won't start. My mechanic passed away last Friday and I really can never afford to put money into my car so I'm trying to avoid paying to have it towed and pay the cost of another mechanic I'm not familiar with so any diagnosis options I can get as to what might be the problem would help me greatly. I'm hoping someone is on right now that can answer me before I leave for work in a hour otherwise I will have to have it towed later on this morning. When I first tried to start it the other night and I turned on the ignition it was clicking. Then it stopped completely and there is now nothing. The battery cables are tight and there is a cylinder looking thing on the opposite side of the car that continues to making a funny clicking sound even after I've gotten out of the car. Any suggestions? Mechanic on the phone thinks starter?
Feb 23, 2006 at 8:11 PM
MVANNESSJR
  • 223 POSTS
Could be a starter, but a dead battery will also prevent it from turning over. Make sure the battery is charged -- maybe jump the car and see if it goes?
Feb 24, 2006 at 3:59 AM
CREMALEY2
[quote:8f51324640="mvannessjr"]Could be a starter, but a dead battery will also prevent it from turning over. Make sure the battery is charged -- maybe jump the car and see if it goes?[/quote:8f51324640] :D You were absolutely correct with your diagnosis!! Thanks!!
Feb 24, 2006 at 7:40 AM
Suggested Repair
Charge or jump-start the battery first. A dead battery can cause clicking and a no-crank even with tight cables. If a good battery still will not crank the engine, have the starter checked.
Conversation Summary
The owner of a 1995 Buick Park Avenue reported a no-start: the ignition clicked at first, then nothing happened, while a cylinder-shaped component kept clicking. The battery cables were tight, and a mechanic suspected the starter. An expert said it could be the starter but a dead battery would also prevent cranking, and advised charging or jump-starting the battery. The owner later confirmed that diagnosis was correct.
