1994 Buick LeSabre Caliper Bolt Size
1994 GMC
NORM'S DAUGHTER
1994 Buick Lesabre
front disc brake caliper
what size torque bit to use to remove caliper bolts(i think it's T 50 but want to make sure before I buy one)
mileage is142193
Mar 19, 2006 at 8:36 AM
MVANNESSJR
  • 223 POSTS
Torx bit? Are you sure? Because I don't think so... Should be a 10mm or 3/8" (depending on the vehicle, can't remember yours specifically) allen-head (hex) tip. This tip is available at most auto supply stores for about $5 and may actually be labeled a "disc brake caliper socket".
Mar 19, 2006 at 6:51 PM
Suggested Repair
Do not buy a T50 Torx bit. Use an allen-head hex disc brake caliper socket, typically 10mm or 3/8 inch, sold at most auto parts stores for about $5.
Conversation Summary
The owner of a 1994 Buick LeSabre with 142,193 miles asked what size Torx bit removes the front disc brake caliper bolts and suspected T50. The expert said the bolts are not Torx and should take a 10mm or 3/8-inch allen-head hex tip, often labeled a disc brake caliper socket, though the exact size for this vehicle was not confirmed.
