which torque bit to remove caliper bolt on a 94 lesabre
1994 GMC
NORM'S DAUGHTER
1994 Buick Lesabre
front disc brake caliper
what size torque bit to use to remove caliper bolts(i think it's T 50 but want to make sure before I buy one)
mileage is142193
Mar 19, 2006 at 4:36 PM
MVANNESSJR
  • 223 POSTS
Torx bit? Are you sure? Because I don't think so... Should be a 10mm or 3/8" (depending on the vehicle, can't remember yours specifically) allen-head (hex) tip. This tip is available at most auto supply stores for about $5 and may actually be labeled a "disc brake caliper socket".
Mar 20, 2006 at 2:51 AM
