rear brakes - 2004 LeSabre
RORLINI1
How easy it to change rear brakes on a 200-2005 LeSabre. I have the kit to retract the calipers.
Anything else I should know?
RO
May 21, 2007 at 4:27 AM
BOOTDOG
  • 665 POSTS
disc brakes are simple. just unbolt the caliper, remove the outer pad, leave the inner pad in till the piston is pressed in, install the new pads, make sure the glide pins move freely and are not binding, bolt the caliper and you're done!! be sure to pump the brake pedal till the pedal is firm before you drive. this seats the pads against the rotors. hope this helps
Aug 15, 2020 at 4:07 AM
