2001 Buick LeSabre Brake Bleeding
USCAVSCOUTS71
Does anyone know how to bleed the brakes on a 2001 Buick LeSabre Limited? I heard that there is a special procedure for it.
Jan 28, 2007 at 6:58 PM
GARFIELD
  • 197 POSTS
There is not anything special that is required other than ensuring the power is off so the ABS module does not get air bound(very bad). I normally disconnect the negative lead on the battery so I know that it will not have any power and then bleed the brakes like you would any other car. This goes for any ABS equiped car.
Jan 28, 2007 at 9:11 PM
Suggested Repair
Disconnect the negative battery cable so the ABS module has no power, then bleed the brakes using the normal procedure.
Conversation Summary
The owner asked how to bleed the brakes on a 2001 Buick LeSabre Limited and whether a special procedure is required. The expert said nothing special is needed beyond keeping power off so the ABS module does not become air bound. Disconnect the negative battery cable, then bleed the brakes as on any other car. This guidance applies to ABS-equipped vehicles generally.
