Have you had the computer reprogrammed with the updates? Also check the u-joints and rear diff. You can do this by setting the parking brake, putting the vehicle in neutral, then crawl under and rotate the drive line back and forth while listening for the clunk and trying to move it around different directions at the u-joints checking for play.
SPONSORED LINKS
Tuesday, April 18th, 2006 AT 8:21 AM
