1994 Pontiac Sunbird Stalls Slowing Down
GMC
I have a 1994 Pontiac Sunbird with 210,000 miles. Haveing problems with this car stalling, car is fine when driving on highway, but when I slow down to make a turn it dies, will start right back but when I try to put it into gear it dies, after 10 or 15 mins it will go. HELP ! ! ! :?
Apr 24, 2006 at 11:38 PM
Tough question. I will say that your engine is about a 100K engine. Anything over that is on borrowed time. A mechanic needs to check it out to determine what codes are set. Good luck
Apr 25, 2006 at 4:57 AM
The car has set no code. It runs great most of the time, just stalls when I slow down. Is it possible that I have a fuel pump problem?
Apr 25, 2006 at 5:12 AM
Same thing here.
https://www.2carpros.com/forum/92-cavalier-hesitates-while-decelerating-or-coming-to-a-stop-vt8988.html
I've tried what was first said with limited success. Haven't tried the transmission yet.
Apr 25, 2006 at 5:44 AM
As far as Transmission goes I have replaced the filter and fluid, this did not help.
Apr 25, 2006 at 7:41 AM
Hummm. I have seen this problem a few times. It could be that the torque converter is in the locked position and isn't acting as a torgue converter anymore but a straight piece of steel.
Apr 25, 2006 at 7:58 AM
Is there any way to check the torque converter?
Apr 25, 2006 at 8:36 AM
Short of a dismantle of the tranny there is none except a few old mechanics tricks.
First unplug your brake light switch and disconnect the purple wire. You may have to cut it but it can be put back together. This is the power to the torque Converter. Plug the sw back in so you will have brake lights.
Put the car in neutral and about 2K RPM go quickly from drive to reverse back and forth. In 90% of the cases I have "unlocked" the converter. If it unlocks you will be able to drive the car but you won't have that 200 rpm decrease when the converter locks up.
Don't reconnect the purple wire until you have a new torgue converter installed. (about $300.00)
Let me know. I will be off line until Sunday.
Apr 25, 2006 at 9:18 AM
I have unplugged the purple wire on the brake light switch (TCC selinoid). Car seems to be runnin fine, has not stalled since I unplugged it. Thanks ......
May 1, 2006 at 8:22 AM
I guess my 40 years as a garage owner has paid off. I am glad I could be of help. losone
May 1, 2006 at 10:08 AM
Suggested Repair
The stalling was traced to a torque converter clutch that stayed locked. Disconnecting the purple TCC power wire at the brake light switch stopped the stalling. Replace the torque converter and do not reconnect that wire until the new converter is installed.
Conversation Summary
A 1994 Pontiac Sunbird with high mileage stalled when slowing for turns and died when shifted into gear, then ran normally after 10 to 15 minutes. No codes were set, and changing the transmission fluid and filter did not help. The expert suspected a locked torque converter and suggested disconnecting the purple TCC wire at the brake light switch. After that wire was unplugged, the stalling stopped, confirming the converter should be replaced before the wire is reconnected.
