Problems with car driving.
PONTIAC
ALEEB
Hi Im new to the forum and have a question about the way my car is driving. I have a 1993 Pontiac Subird LE, with a 2.0L engine and approx. 105k miles on it.
Everytime my mother or I drive it, it stalls heavy. It' ok sometimes but gets worse the longer it's driven. It holds back like it does not want to drive. My mother and I replaced just about everything from spark plugs and cables, gas filter, air filter, oil change, etc. but it still acts the same. My mother recently told me that the reason it has been acting like that is because she just found out that my uncle put in one of the spark plugs wrong and now the engine has a gap in the hole where the plug was incorrectly put in.
do you think this could be the reason for my car to drive so poorly and if so is there anything that I could in order to correct the problem? thanks in advance for the help.
Apr 22, 2007 at 5:22 PM
SERVICE WRITER
  • 9,123 POSTS
"gap in the hole where the plug was incorrectly put in"
Can you elaborate on that?
Apr 22, 2007 at 11:03 PM
ALEEB
Yes. The plug was screwed in crooked so now it's hard to properly allign any spark plug that goes into the hole.
Apr 23, 2007 at 4:26 AM
SERVICE WRITER
  • 9,123 POSTS
That's a problem, may or may not be related to the stalling. regardless that should get taken care of. May need to pull the head, unless a heili coil can be put in.
Apr 23, 2007 at 11:36 AM
ALEEB
Do you know what could cause the stalling because I really want to get it taken care of. Thanks for the replies.
Apr 25, 2007 at 9:07 AM
SERVICE WRITER
  • 9,123 POSTS
No I don't. The stalling can e a multitude of possibilities, but regardless if there is a lack of compression from the plug not sealing, that will take priority in your journey.
Apr 25, 2007 at 2:09 PM
ALEEB
Ok, I thank you for all of your assistance.
Apr 26, 2007 at 3:08 AM
