1982 GMC Truck Speedometer Not Working
GMC
LEOORLANDOJR
I have a 1982 GMC Truck and have recently replaced the speedometer cable but still it does not work. Can you tell me what else it might be. Thanks. Leo O. Martinez Jr.
Feb 5, 2007 at 6:17 AM
MICKEY-D
  • 304 POSTS
It could be the gear the the cable fits into on the trans, or it could be the gear inside the trans. Might even be the speedo head. Unhook the cable from the speedo and drive the car, see if the cable is turning. If it steady turns, and you can't stop it with your fingers, it's the speedo head.
Jan 7, 2010 at 3:32 PM
Suggested Repair
With the cable disconnected from the speedometer, drive and check whether the cable turns steadily and cannot be stopped by hand. If it does, replace the speedometer head. If it does not turn, inspect the drive gear where the cable enters the transmission and the gear inside the transmission.
Conversation Summary
The owner of a 1982 GMC truck replaced the speedometer cable, but the speedometer still does not work. The expert said the problem may be the gear the cable fits into, the gear inside the transmission, or the speedometer head, and recommended checking whether the disconnected cable turns while driving.
